Has this been reported? I have a page where I am using {note} in a section with a H1. header at the top of the section. The following section I also started with an H1. header and it will not be underlined. There are other subsequent issues that pop up down the page.
Has anyone experienced this before or know of a work-around?
Hi Jay,
insert a column within the section and everything should be fine again:
{section}
{column}
h1. your text
{column}
{section}
Best regards
Thomas
Yup, that got it. Hope that gets fixed soon, bit awkward otherwise. Thanks
