Hi all,
when I run the
atlas-run-standalone --product jira
command and open the provided link http://elenas-macbook-pro.local:2990/jira/ I get a fatal error which I screenshoted above. Did anyone else encounter this problem?
I use
OS X 10.10.3 (14D136)
Further information:
atlas-version
Elenas-MacBook-Pro:~ elecos$ atlas-version ATLAS Version: 5.1.10 ATLAS Home: /Applications/Atlassian/atlassian-plugin-sdk-5.1.10 ATLAS Scripts: /Applications/Atlassian/atlassian-plugin-sdk-5.1.10/bin ATLAS Maven Home: /Applications/Atlassian/atlassian-plugin-sdk-5.1.10/apache-maven-3.2.1 AMPS Version: 5.1.18 -------- Executing: /Applications/Atlassian/atlassian-plugin-sdk-5.1.10/apache-maven-3.2.1/bin/mvn --version -gs /Applications/Atlassian/atlassian-plugin-sdk-5.1.10/apache-maven-3.2.1/conf/settings.xml Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256M; support was removed in 8.0 Apache Maven 3.2.1 (ea8b2b07643dbb1b84b6d16e1f08391b666bc1e9; 2014-02-14T18:37:52+01:00) Maven home: /Applications/Atlassian/atlassian-plugin-sdk-5.1.10/apache-maven-3.2.1 Java version: 1.8.0_25, vendor: Oracle Corporation Java home: /Library/Java/JavaVirtualMachines/jdk1.8.0_25.jdk/Contents/Home/jre Default locale: de_DE, platform encoding: UTF-8 OS name: "mac os x", version: "10.10.3", arch: "x86_64", family: "mac" Elenas-MacBook-Pro:~ elecos$
javac -version
Elenas-MacBook-Pro:~ elecos$ javac -version javac 1.8.0_25
Best,
Elena
It is asking you to restart. Does it happen even after restart? Make sure you don't clean the current instance before starting again.
