I am trying to connect to connect to my JIRA cloud instance using JIRA-Python. The following code worked for me at at first:
server = {'server': myServerAddress} jira = JIRA(server, basic_auth = (myusername, mypass))
I was able to connect to both my local instance and the clound instance using this code previously. However, when I run the same exact code now, I get the error:
MissingSchema: Invalid URL 'https:/myinstance.atlassian.net/rest/api/2/serverInfo': No schema supplied. Perhaps you meant http://https:/myinstance.atlassian.net/rest/api/2/serverInfo?
It might be that something about my instance that has changed, but I'm at a loss for what it could be. Does anyone have any insight as to what could be causing this?
It looks like you are missing a / from the url - https://
