JIRA 6.1 __MSG_gadget.project.pivot.title__ for Project Pivot Gadget
Andriy Zhdanov
September 24, 2013
Can someone know what's the problem? With JIRA 6.1 Project Pivot Gadget title and description are not resolved for Timesheet plugin, i.e.:
Add gadget
See also Issue #419 and JRA-35036.
Thank you.
Andriy Zhdanov
September 30, 2013
This was solved by minor correction in pivot-gadget.xml, sorry for bothering.
SJ March 17, 2014
Can you please explanin what u did ???
I am also facing the same problem. I am not getting the title and description ????
Andriy Zhdanov
March 17, 2014
Richard Plana
October 28, 2013
We have a similar issue with versions:
Plugin Version: 2.0
JIRA Versions: 4.0 - 4.2
Is there a resolution for a system where the plugin has already been installed and for a new install? We're evaluating it on a test server and would first like to fix it there.
Andriy Zhdanov
October 29, 2013
Hi Richard,
Could you please try applying fix manually? See https://bitbucket.org/azhdanov/jiratimesheet/commits/53c05e2
You need to extract project-pivot-gadget.xml, apply changes, update plugin jar and reinstall (preferrable uninstalling first, restarting jira and installing again)
You can extract and update jar with the following commands:
$ jar xf jira-timesheet-plugin-2.0.jar src/main/resources/project-pivot-gadget.xml
$ jar uf jira-timesheet-plugin-2.0.jar src/main/resources/project-pivot-gadget.xml
Hope it will help.
Thank you.
Andriy Zhdanov
September 24, 2013
I expected this, sorry, forgot to add origin Issue #419
Henning Tietgens
September 24, 2013
