Jira not starting up -- Need help urgently
Rahul Aich [Nagra]
July 14, 2013
Hi All
the problem is jira is not starting up at all. In the logs it gives you this error (see below).
On front end it gives you message
Error occurred while starting component 'com.atlassian.jira.plugin.profile.DefaultUserFormatMapper'.
Help please?
Rahul
2013-07-14 22:21:35,553 Thread-1 ERROR [com.atlassian.jira.ComponentManager] Error occurred while starting component 'com.atlassian.jira.plugin.profile.DefaultUserFormatMapper'.
java.lang.IllegalArgumentException: Invalid complete key specified: null
at com.atlassian.plugin.ModuleCompleteKey.<init>(ModuleCompleteKey.java:17)
at com.atlassian.plugin.manager.DefaultPluginManager.getEnabledPluginModule(DefaultPluginManager.java:766)
at com.atlassian.jira.plugin.profile.DefaultUserFormatMapper.ensureCurrentMappingsValid(DefaultUserFormatMapper.java:118)
at com.atlassian.jira.plugin.profile.DefaultUserFormatMapper.start(DefaultUserFormatMapper.java:107)
at com.atlassian.jira.ComponentManager.quickStart(ComponentManager.java:254)
5 votes
Bhushan Nagaraj
July 14, 2013
Take a look at
https://jira.atlassian.com/browse/JRA-19460
Cheers
Bhushan
3 votes
Rahul Aich [Nagra]
July 24, 2013
Hi All
Thanks for all your comments. I managed to resolve this issue.
When i tried to xml import the same file again after a few hours it imported fine, jira started perfectly.
the issue may be due to memory running out during xml import and thus corrupting the database and preventing a start up.
But this is just a hypothesis, no way i can prove it now, since the issue is no longer replicable.
But if anyone can suggest any other possible root causes, then it will be great
Rahul
Naren
July 14, 2013
What is the JIRA version you're trying to upgrade to?
Mizan
July 14, 2013
Can you provide more logs . From starting of JIRA till the error/end . You can save it as a text and upload it to a comment
Rahul Aich [Nagra]
July 14, 2013
HI Bhushan
I am on 4.1.2, about to upgrade to higher version. There are just three custom plugins i use, Jira charting plugin, greenhopper and Jira workflow misc extensions.
The instance worked fine until now. Today morning i tried to do an restore from xml, that failed, when i tried to rollback even that failed, after that jira failed to start up with this error.
Bhushan Nagaraj
July 14, 2013
What version of Jira are you using? What plugins are you using?
