I am configuring SQL for confluence plugin but i am getting the below error.
Error rendering macro 'sql-query' : Unable to load database driver: net.sourceforge.jtds.jdbc.Driver. Make sure your configuration is correct
Followed steps:
Step 1: Placed jtds-1.3.1.jar under lib directory.
Step 2: updated the context.xml under conf with the below.
<Resource name="jdbc/InventoryDB"
auth="Container"
type="javax.sql.DataSource"
driverClassName="net.sourceforge.jtds.jdbc.Driver"
url="jdbc:jtds:sqlserver://servername:1433/dbname;instance=UAT"
username="username"
password="password"
maxActive="10"
maxIdle="10"
validationQuery="Select 1"
Step 3: restarted Tomcat
Step 4: in the sql plugin configuration screen updated the information.
Add a profile named: InventoryDB
with profile value:
dbDriver=net.sourceforge.jtds.jdbc.Driver | dbUrl=jdbc:jtds:sqlserver://servername:1433/wiki;instance=UAT| dbUser=username|dbPassword=password| dbJar=lib/jtds-1.3.1.jar
Can Some one Please let me know if i am missing anything from my end ?
First, you only need one of these configurations. Either application defined data source (your first 3 steps) or the data source profile configuration. See Data Sources for more information.
In your case, the data source profile configuration will override the other configuration. I suspect you Confluence server is on Windows. Suggest setting the dbJar to the full path name to the jar file.
If you still have problems, please open a support issue.
