Updated Firefox to 38.0.5 yesterday, and also installed the Capture add-on. I usually browse with my bookmarks sidebar visible, and on the left hand side of the screen.
When I installed the Capture add-on, it switched my bookmarks sidebar to the right hand side, which I don't like. (There's nothing inherently wrong with it being there, and it behaves as normal, I just don't like it there). It stays there even if I am not using Capture at the time, and goes back to the left if I disable the add-on.
When I click the Capture button it replaces the bookmarks sidebar with the Capture sidebar, which I can understand, just wonder why Capture doesn't just replace it wherever it already happened to be?
Hi Toby,
JIRA Capture in Firefox is configured to be displayed on the right side. Looks like somehow this configuration is propagated to other browser elements too. Can you please raise an issue on jira.atlassian.com/browse/BON for this?
Thanks!
Cheers,
Ignat
JIRA Capture Developer at Atlassian.
