Help programming an auto-comment for when a comment is added to a closed issue
Mike Thomas May 6, 2024
When an issue has been resolved/canceled and someone happens to add a comment to it, the assignee is not notified due to it being closed. I wanted to create an automation to generate a comment which would then send an email in the even someone happens to add a comment on a closed/cancelled issue.
When creating this automation, it was working but what we learned was happening is when someone went to resolve a case, this new automation would kick in right away and leave the new comment because the timing/order of the case being closed, it triggered it instantly. I then figured we could establish a 1-2 minute delay, which is where I'm getting stuck.
On the attached screenshot, if I change the Second Value to "-2", the automation works, however we are getting the same results as before (everything happening all at once). However, when I remove the negative sign, the automation simply isn't working.
I've removed the negative sign and went in and added a comment to my test closed case, but i'm getting no results from this automation. My hope here is by removing the negative sign and once i place a comment on a closed case, in 2 minutes the automation would kick in and add the comment. Note; If I add back in the negative sign (-2), it works but for any open cases that get closed, we are back to square one where this automation kicks in and adds the comment when someone resolves the case.jira_comment1.JPGjira_comment2.JPG
Kian Stack Mumo Systems
Community Leader
Community Leader
Community Leaders are connectors, ambassadors, and mentors. On the online community, they serve as thought leaders, product experts, and moderators.
May 7, 2024
Try this condition -
{{issue.comments.last.created.diff(issue.resolutiondate).minutes}} LESS THAN -3
